My firm does a lot of multi-family projects, and we recently started making use of area plans to track realtime updates to the areas (finally moved away from filled regions, YAY) with the use of the area tags. However, we then manually enter this value into different parts of the project, like in the view title on the individual unit plan sheet, or in a schedule on one of our general sheets which lists all the different unit types, their individual areas, and quantities.
Is there a way to extract this area from each unit’s area plan, and populate other places in the project with this value?
I myself have only dipped the very end of my toe into the Dynamo pool, and the firm as a whole has even less experience, for what it’s worth.
The first is to not try and use Dynamo to replicate a bad practice.
The area in the view title likely should be a tag in the view (or rather just below the view extents, not the annotation crop extents though). Done that way and you’ll never have an incorrect value again, nor will you have to chase writing the value or making sure an automation runs before you hit print.
The schedule should be a schedule which reports the area parameter value, no text copying required.
This doesn’t mean there aren’t valid use cases for this task, but that you shouldn’t ignore best practices in Revit because there are tools which copy data from one field to another.
The second is some authoring advice.
Use the extended node help found found in the documentation browser (right click a node and select ‘help’) to learn how a node works.
Install 2027.3 and make use of Autodesk Assistant to get help with authoring the graph. Prompt it in such a way to get incremental updates (“help me set something up so I can get the area of the unit a given view of this type is built for” might be a good start). The key to long term success here is to use the agent to learn small steps, not ask it to build the full solution. The learning approach will give you a knowledge base to build off of in the future while providing a functional tool, while the later won’t be more useful than the immediate solution.
Some potentially useful nodes are: Document.ActiveView, Select Model Element By Category or All Elements Of Cateogry In View, Element.GetParameterValueByName and Element.SetParameterValueByName
Jacob’s right that a tag is the way to go for the unit plans. If you put an Area tag in each unit’s plan view, it always shows the current area, so there’s nothing to retype when the layout changes.
For the unit type schedule on your general sheet, you can make an Area schedule (View > Schedules > Schedules/Quantities, then pick the Areas category for your area scheme) and add the Name and Area fields. That pulls the numbers straight from the area plans. Quantities depend on how you’ve modeled things. If every unit in the building has its own Area, you can group by Name, turn off “Itemize every instance,” and add a Count field. If you only have one area plan per unit type, the schedule can’t count them for you.
Dynamo is really only worth it if the area has to show up somewhere a tag can’t reach, like a field in your title block. In that case the graph would grab all the Areas, read each one’s Name and Area, find the sheet that goes with it (for example, an area named “Unit A” goes on the sheet named “Unit A”), and write the area into a shared parameter on that sheet. The value only updates when you run the graph, so you’d run it before printing.
I build custom tools for this kind of thing on multifamily projects, so feel free to message me if it turns into a bigger job.
Ah yes, both replies here bring up good points for me to clarify:
Our office largely uses Revit 25 right now, with new projects being started in Revit 27. So while I had thought about using Revit 27’s built in Assistant, I haven’t had the chance to use it myself.
For our units, we have have “working” units in groups off to the side of the main building footprint, with a working view set up which shows them all. Similarly, an area plan view is created with all these units, where unit area is shown and tagged. Finally, seperate sheet views are created for each individual unit with annotations, dimensions, etc.
I love the idea of using the area tag to display the area, though I’m not sure how this will work in our current workflow as the area plan is an entirely different plan than what we put on our sheets. I’ll have to dive into a project myself to see if this is possible.
bimautomationstudio, I may pick your brain on workflow possibilities, as I definitely see areas in which we can be more efficient.
Good to know on the setup. Area tags only work in area plan views, so they can’t go straight into the unit views on your sheets. One way around it is to duplicate the area plan as dependent views, crop each one to a single unit, and put those on the unit sheets. Dependent views share the original’s tags, so the area shows up in each one. The catch is your dimensions and notes would have to be redone in those views. Happy to talk through it anytime, just send me a message.
if i really understand the whole workflow it can be fully automatic with dynamo…ceate area plans, create an area in these bounderies curves and maybe create views, tag it, crop it if needed and can even create a color legend for that, fully atomatic with dynamo…in 1 run
No. Right. You can just simply stack Views
on the Sheet(s). Just turn of the stuff in the Area
Plan what is already on the other Plan
Or am i misunderstanding?
Maybe OP can post an example drawing of the
end result they are after?
