Greeting,
Extract 2 insertion points(X,Y and Z) of 3 reference planes(“Left“, “Right“,“Center((Front/Back)“) from Revit family in project. Z value is the same as the family’s insertion’s elevation.
As shown below
The sample Revit family is attached.
E.rfa (408 KB)
Thank you for the help in advance.
What have you tried so far? What issues are you running into? Have you accessed the family in the Family Editor environment? Can you get the reference plane geometry?
How to get help on the Dynamo forums - FAQ - Dynamo
Intersecting two planes is a no-no for ASM as the resulting curve is unbound. As such this gets a bit odd, but there is a simple fix should you have all planes perpendicular to each other.
However even though two planes intersecting would result in a rat, @Steven2026 indicated a point is the expected result, so I’m going to assume these planes are perpendicular to the internal XY plane.
Good code would check the angle between the normal of the front/back plane to the left and right planes to assure this is the case but I will assume that @Steven2026 has already done this manually or can implement similar if needed.
- Generate a point at the origin.
- Get the closed point on the front/back plane to the point.
- Get the closest point on both the left and the right plane from the projected point.
As the closest point to any plane is always normal to its face and the planes are perpendicular to each other this should return the points which are targeted.
If the desired elevation is another named reference plane you can first confirm it’s normal is also perpendicular, and then get the closest point on that plane from the projected points on the left and right plane.
A workaround using temporary dimensions.
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
toList = lambda x : x if hasattr(x, "__iter__") and not isinstance(x, (str, System.String)) else [x]
lstelems = toList(UnwrapElement(IN[0]))
lst_plane_name = toList(IN[1])
out = []
for instance in lstelems:
basisX = instance.GetTransform().BasisX
base_line = DB.Line.CreateUnbound(instance.Location.Point, basisX)
plane_RefA = instance.GetReferenceByName(lst_plane_name[0])
plane_RefB = instance.GetReferenceByName(lst_plane_name[1])
ref_array = ReferenceArray()
ref_array.Append(plane_RefA)
ref_array.Append(plane_RefB)
# create a temporary dimension
dim = doc.Create.NewDimension(doc.ActiveView, base_line, ref_array)
doc.Regenerate()
curvDim = dim.Curve
direction = curvDim.Direction
# get points
start = dim.Origin - (direction * ( dim.Value/2))
end = dim.Origin - (direction * (-1 * dim.Value/2 ))
out.append([start.ToPoint(), end.ToPoint()])
# remove dimension
doc.Delete(dim.Id)
OUT = out
Thank you so much for the help. This is exactly what I need. The full script as below just incase if anyone wants to use it.
