Export and Import Family Type Images in the Family Editor
Wanted to share this graph that is able to export an image of each Type in the Family Editor to a folder and then set the exported image to the Type Image for the same type.
  1. Pick a Folder to Export the Images
  2. Make sure all of the types have the correct parameter settings.
  3. Run!
Python:
#Sean Page, 2023
import os
clr.AddReference('RevitAPI')
clr.AddReference('System')
results = []
types = doc.FamilyManager.Types
grp = TransactionGroup(doc)
grp.Start("Export Views")
for type in types:
	t = Transaction(doc)
	t.Start("Export Type")
	doc.FamilyManager.CurrentType = type
	t.Commit()
	opts = ImageExportOptions()
	opts.ExportRange = ExportRange.CurrentView
	opts.FitDirection = FitDirectionType.Vertical
	opts.ZoomType = ZoomFitType.Zoom
	opts.PixelSize = 400
	opts.ImageResolution = ImageResolution.DPI_150
	opts.FilePath = os.path.join(IN[0],type.Name)
	results.append(type.Name)
	doc.ExportImage(opts)
	t.Start("add image")
	for param in doc.FamilyManager.Parameters:
		if param.Definition.Name == "Type Image":
			#MessageBox.Show(opts.FilePath);
			imgOpts = ImageTypeOptions(opts.FilePath +".png",False,ImageTypeSource.Import)
			img = ImageType.Create(doc, imgOpts)
			doc.FamilyManager.Set(param, img.Id)
			break
	t.Commit();
grp.Assimilate();
OUT = results
Export Type Images.dyn (5.7 KB)
Hello. Thanks for sharing this script. The name of the file is the name of the type (80 x 210 cm.png) but,… How can the name of the family be added to the name? (Puerta de 1 hoja-80 x 210 cm.png). Thanks. Regards
Yes, we can use the Title property of the Document to append the Family name, assuming it has been saved at least one time.
thanks very interesting. I am wondering how to do the reverse, there is a family type parameter builtin called Type Image where there is an image loaded in the parameter of the family, I want to extract it to a folder instead of inserting (setting) it in the parameter type Image.
So, this gets a little harder to do, but here is a way to start:
#Sean Page, 2024
if isinstance(IN[0], list):
	element = UnwrapElement(IN[0])
	element = [UnwrapElement(IN[0])]
results = []
#Get all Family Parameters
params = doc.FamilyManager.Parameters
#Iterate Parameters
for param in params:
        #Images are stored as ElementId
        if param.StorageType == StorageType.ElementId:
                #Get the element from the parameter
                elem = doc.GetElement(doc.FamilyManager.CurrentType.AsElementId(param))
                #Check to see if the element category is Raster Image
                if elem.Category.BuiltInCategory == BuiltInCategory.OST_RasterImages:
                    #use the GetImage method to return the bitmap
                    results.append(elem.GetImage())
OUT = results
maybe ending with something like that?
# Add reference to System.Drawing for image manipulation
clr.AddReference("System.Drawing")
from System.Drawing import Image
from System.Drawing.Imaging import ImageFormat
import System
# Directory to save images
outputDir = "C:\\path\\to\\save\\images"
if not System.IO.Directory.Exists(outputDir):
    System.IO.Directory.CreateDirectory(outputDir)
# Assuming `results` contains System.Drawing.Bitmap objects
for idx, bitmap in enumerate(results):
    # Construct a file path using str.format method
    filePath = System.IO.Path.Combine(outputDir, "image_{0}.png".format(idx))
    # Save the bitmap to file
    bitmap.Save(filePath, ImageFormat.Png)
How can I export images of each type of wall in the project?
Get the Wall type then GetPreviewImage().
https://thebuildingcoder.typepad.com/blog/2010/05/get-type-id-and-preview-image.html
can you be specific
Here is what’s inside the python just to sequence the image names for saving.
#Sean Page, 2024
path = IN[0]
rng = IN[1]
OUT = [path + " " + str(i)+".png" for i in range(len(rng))]
test image 2
I want it to show in full (including doors if any)
Ok, then it’s probably easier for you to show us what you’ve done and we can try to help from there.
