Expected Level, got Level
Hi
I use Revit Node library to create new Elements.
I push: Line, Level and FamilyType but Dynamo Python show Error
But the same arguments and create by Dynamo Node work fine.
clr.AddReference('RevitAPI')
p1 = XYZ()
p2 = XYZ(2,0,0)
line = Line.CreateBound(p1,p2).ToProtoType()
#get familytype
ftype = Revit.Elements.FamilyType.ByFamilyNameAndTypeName("UB-Universal Beams","UB305x165x40")
#get level
Alllevel = FilteredElementCollector(doc).OfClass(Level).WhereElementIsNotElementType().ToElements()
level = Alllevel[1]
#OUT = line,level,ftype
#Create beam
beam = Revit.Elements.StructuralFraming.BeamByCurve(line,level,ftype)
OUT = beam
ExpectedLevel.dyn (16.0 KB)
I tried change level to IN[0] and it worked, :rofl:
ExpectedLevel.dyn (17.1 KB)
This is a call to the Dynamo node for creating a beam, so all of the inputs need to be Dynamo wrapped elements of their Revit equivalent. Instead of wrapping it is likely easier to use the Revit API call directly, as both your level and curve are already Revit native data types.
I believe that this is the API call to create a beam: NewFamilyInstance Method (Curve, FamilySymbol, Level, StructuralType)
You will also need to change your method for collecting the family type, utilizing a filtered element collector as you did in the levels instead of the by family name and type call to the Dynamo node.
You will also need to provide the structural type, the method of which is here: StructuralType Enumeration
Try to wrapp the level into DynamoObject ( necessary to import extension)
level = Alllevel[0].ToDSType(True)
Thank you so much!
