Hi everybody,
I’m currently working on a script which give me the exact perimeter and area of my room boundaries (Without doors, windows and room separation line, …). The script is working perfectly but only for one room …
The script is gathering all the room in the models with the nodes “Categories” and “All element of categories” so if I run it on a model with multiples rooms, all my values are falses.
I guess that the easiest way to solve the problem would be to execute the script for on room after an other but I’ve no idea how to do it. I could use a “Select Model Element” node and run the script on each room but it wouldn’t be very efficient …
Here is the script :
Métrés finitions.dyn (36.1 KB)
Thanks you for you help !
Nathan
