Hi All,
I imported excel data from excel to dynamo, and doing some filtering works in dynamo.
When I filter some “Word” (e.g. Good), the filtering node is workable. However, it cannot work when filtering some “number” the node.
I tried to change “number” type, but the result is same…What is the problem ? Please help to solve.
Thank you.
Hello
Try passing “264462.000” as a String in Code Block Node rather than passing only 264462.
Let me know if that doesn’t work.
Thanks,
Ritesh
Hi Ritesh,
Your suggestion is work, thank you !!
But why imported data from excel to dynamo, the number will added " .000" on the end of the number (my all data is integer) ?
How to change number to integer on my group data ?
I attached my excel and dynamo file for your information.
Filtering Parameter to Revit
Testing Summary
Thank you again~
