Error reference not set to an instance of an object
Hi Everyone!
I have a problem with dynamo, when i debug me package it show error in my screen dynamo. I’m still using normal dynamo if I don’t debug my code. Has anyone got this error yet, please help me, thanks a lot!
[image]
Search the forum for the HelixToolKit error message, it seems to be a dependency on an older DirectX driver.
Thank you. Answers are appreciated!
hmm, this only happens when you are debugging your own package?
What dependencies does your package have? Are you referencing some of Dynamo’s core binaries and leaving copy local set to true in your reference properties?
Maybe an image of you package’s bin folder will help, or a simple GitHub repo that reproduces the issue.
I tried removing all other developers’ packages and it worked fine for me. Thank you very much.
Hi guys !
I am having a similar issue here any ideas ?
It not same, please check again object input is null
Hi @chuongmep ! I’ve checked that the input is not null and the problem still exists .
I am having a similar experience.
My package is working perfectly on my machine, but on the client’s, with the same version of Revit and Dynamo, same routine, same model, same Revit language, it’s not working.
Very bizarre.
