Hi all.
Element set parameter by type is not working because no parameter is found by that name. I am using revit 2023. Any Ideas?
Hi @technitutors hard to say if you can show what you try to feed in then we probably can help
“Type” is not a parameter, “Type Name” is a parameter. and remember to put an element.elementtype node in between if you want to change type parameters.
test2.dyn (37.2 KB)
here it is. Both scenarios dont work
You need to show us the data going into the element port. Ideally with an added branch with a single Element.Parameters node showing the list of parameters available for one of the elements.
they are all structural framing elements
Ok. Take one out of the list and show what parameters are available via an Element.Parameters node.
Is this something to do with Revit 2023? It always used to work with type.
Is the parameter you are looking for found in that list?
yes type is instance…
