I want to get a list of elements which are intersecting the solid. But the node(Element.IntersectsSolid: Bimorph) doesn’t work for this situation. But the funny thing is If I change the solid to boundingbox then it works. What do I need to change? I want to use solid because solid can be used for more specific geometirical info.
Does Cuboid and Solid are at the same place?
No. That’s the reason that I don’t want to use the Cuboid(Boundingbox),Solid is smaller than Cuboid in this case.
BoundingBox is convex box around geometry, it’s not a error. Share your file, i’ll see what we can do.
Thank you for your replying. The file is related to my work. so, because of the safety reason unfortunately I can’t upload this file…
And result is 15 fixtures? Analyze, why are they in list?
Get all solids from your geometry, try to find out, if solids are intersecting?
Use LinkElement.Solid and Does.Intersect for check solids intersections.
Amigo @jaeho Buenas, I will look at your script to see if I am able to understand what you need and try to help you, meanwhile I leave you a link to a Dynamo Office Hours video, where JacobSmall explains the abstract geometry topics of the Dynamo library and how to use them, it helped me a lot and I hope you too.
Yes. Thank you for your suggestion. But I still don’t understand why the element in in the list when I filtered the fixtures by solid(ceiling).
Cool, I’m glad you found a solution, you’re improving fast, keep it up! ![]()
