Edit lot of family in a revit project?
Don’t use the Parameter node as pictured, this has a different use within workflows.
Instead use the Element.SetParameterByName node :wink:
Though you are trying to change a Family parameter that is usually set within the Familiy Editing environment, so a slightly different workflow will be needed.
You may need to look into ‘background open’ workflows to open a bunch of Family documents, adjust the parameters, save, and reload into the Project environment.
Have a look here for a start :slight_smile:
