In this Revit Dynamo Tutorial, I will explain how you can produce a two-point attractor in dynamo and make an array of boxes based on these points. First, I will explain how you can work in Dynamo and some tips which will help you work easier and then I will explain how you can make an array of points, define attractors and finally relate them to the boxes dimensions.
Watch the full video tutorial at
