I have a list containing 40 sublists. Each sublist contains 10 items (say points A-J along a curve). I would like to end up with a list of sublists, where each sublist contains 2 items like this: List [0] contains 10 sublists. Each sublist contains a list of 2 points: list [0] contains points [A,B], list [1] contains points [B,C], list [2] contains points [C,D], etc…
Against this issue, I am also often. I have found two solutions. For points on a line it is easier:
My second method is to play with the list actions. It is the much longer way.
If anyone knows an easier way, please post
But I’m not quite sure if this was your problem ^^
Figured it out:
- Created a copy of the list
- Using List.RestOfItems, remove first item from one of the lists to offset the values.
- Using List.Chop, divide lists into sublists each containing 2 values.
- Using List.Join, join lists! This actually returns 2 appended lists of sublists, not laced lists of sublists, but that works for me.
NB: Use List.Map to get access to the sublists and apply each function.
