How can I get the Mechanical Equipment connected to particular Air Terminals or Accessory in a model?
Hello @theshysnail
A Python solution to find all elements by system with a selected element in input
#import Revit API
clr.AddReference('RevitAPI')
def getElemBySystem(elem):
find all the elements of the 1st system found
mepsys, elemsSys = None , None
connSet = elem.MEPModel.ConnectorManager.Connectors
for con in connSet:
if con.IsConnected:
mepsys = con.MEPSystem
elemsSys = list(mepsys.Elements)
break
return mepsys, elemsSys
systems = []
elemout = []
toIter = lambda x : x if hasattr(x, "__iter__") else [ x ]
elems = toIter(UnwrapElement(IN[0]))
for e in elems:
sytem, elemSys = getElemBySystem(e)
elemout.append(elemSys)
systems.append(sytem)
OUT = systems, elemout
Thanks.
From what I understand, it’s giving me all the Mehanical Equipment and accessories in the network when I select an MEP accessory (not duct or pipe).
yes then you can filter elements before or after python script (by Category for example)
