Dimension lock (several)
Hi guys,
ive managed to lock 1 dimension line but im trying to lock a list of dimension with python. see graph. when i insert several dimensions i get a warning. can anyone help me on this one. thanks
You need to add a for loop to process each of the dimensions not the list of dimensions.
dims = UnwrapElement (IN[0])
for dim in dims:
    if dim.Segments.Count >0:
        for ds in dim.Segments:
            ds.IsLocked =True
        dim.IsLocked =True
as the error says you are using NumberOfSegments Property with List. Try to use for loop for each element in list.
I did as you sayd @SeanP but i stil get this warning
Just read a error message!
Segments Property returns a read only array of segments in the dimension -> https://www.revitapidocs.com/2020/d7fcdab2-ca81-0ed1-4813-f7aa092430d7.htm
use len(dim.Segments) instead of Count
As noted before:
This works for one string of dimensions, or one individual dimension, but not for two dimensions or for two strings.
The code needs to ensure that a single dimension is converted into a list of dimensions (or strings), and then needs to handle every dimension/string in the list of dimensions.
Otherwise you’ll be pulling properties from an array all day long.
@wihibyusuf Try this:
dims = UnwrapElement(IN[0])
out = []
if not isinstance(dims, list):
    dims = [dims]
for dim in dims:
    if dim.NumberOfSegments>0:
            ds.IsLocked = True
            out.append(dim)
        dim.IsLocked = True
        out.append(dim)
OUT = out
*EDITED after @jacob.small’s comment!
This is close, but what happens if you feed it one dimension instead of 2?
Well done @AmolShah. :slight_smile:
I’ll add a bonus - This add sets the ‘true false’ which was previously only serving the purpose of forcing a regen, so that it either locks or unlocks the dimension:
import sys
clr.AddReference("RevitAPI")
from  Autodesk.Revit.DB import *
lock = IN[1]
if not hasattr(dims,'__iter__'):
	dims = [dims]
for dim in dims:
			ds.IsLocked = lock
		dim.IsLocked = lock
OUT = dims
Likely worth reducing the imports there if this is all you want to do - this feels a bit heavy handed. :slight_smile:
Awesome guys… it has worked. Im thankful for this forum that made this possible.
Thank you guys.
I tried you script, as I have many locked dimns and I want to unlock them. But, when I run the script I got this warning
Warnung:IronPythonEvaluator.EvaluateIronPythonScript fehlgeschlagen.
File “”, line 19, in
IndexError: index out of range: 1
could you please help?
Any chance you only have one input in the Python node? If so you’ll need to hit the + button and add a new input of ‘false’ to unlock the dimension.
It works … thanks a lot
