Hi all,
Please could you tell what am I doing wrong. I need to take the index o the minimum item of a list. If the number is between 0-5, it should be zero (0). Thats the reason of the python code.
The problem is in the IndexOf node, that as a result, it gives different indices for the same number in the two cases (image):
import Autodesk.DesignScript.Geometry
clr.AddReference('DSCoreNodes')
from DSCore import *
diferencia = IN[0]
corregido = []
for i in range(len(diferencia)):
aux = []
for j in range(len(diferencia[i])):
if diferencia[i][j] < 5:
aux.append(0)
aux.append(diferencia[i][j])
corregido.append(aux)
OUT = corregido
What am I missing here?
Thanks in advance!
