Dear all,
I found a problem with the DesignScript command List.RestOfItems().
In the following picture the two results coming from the same DesignScript command are shown:
It is possible to see that the code block 1 and the code block 2 have the same DesignScript command but they have different results.
I am not able to understand the reason of this issue, since that the syntax is exactly the same.
Do you ever faced something similar?
Thank you in advance for your collaboration
what version of dynamo is this?
hmm, can you try using different variable names in code block 2?
FYI @Aparajit_Pratap
@a.menozzi I’ve had the same issue a few times
Might not be the case with you, but the problem was that I was in manual mode and hadn’t clicked Run after rewiring the input/s
Hi @Michael_Kirschner2,
this is the version 1.3.3.4111.
I tried using different variable names but nothing is changing. The results are always the same.
The results will change only if I write another new code block, as the number 1.
@Vikram_Subbaiah Dynamo is in the manual mode actually, but I have run it
