Hi all,
I’m currently working on a script that will remove all avaible supports that are defined in a project.(because it will be part of a bigger script that will run several times and everytime the supports will change.)
here is the list of the supports which are stored.
this is the error i get when running the script.(but labels are deleted, not always. sometimes 1 remains)
File “”, line 28, in
EnvironmentError: System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at Microsoft.Scripting.ComInterop.ComRuntimeHelpers.CheckThrowException(Int32 hresult, ExcepInfo& excepInfo, UInt32 argErr, String message)
at CallSite.Target(Closure , CallSite , Object , Object )
at lambda_method(Closure , Object[] , StrongBox`1[] , InterpretedFrame )
at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at DSIronPython.IronPythonEvaluator.EvaluateIronPythonScript(String code, IList bindingNames, IList bindingValues)
this is the script which i use to delete the labels.
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
start = IN[0]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
LabServ = IRobotLabelServer
LabServ = project.Structure.Labels
RNA = IRobotNamesArray
RNA = LabServ.GetAvailableNames(IRobotLabelType.I_LT_SUPPORT)
count = RNA.Count
for i in range(count+1)[::-1]:
LabServ.Delete(IRobotLabelType.I_LT_SUPPORT, RNA.Get(i))
OUT = "gedaan", count
Does anyone of you know where/what i’m doiing wrong to get this working without any errors?
Thanks in advance
Gr Edward.
Dyname file Delete info 3.dyn (2.4 KB)
for robot file with saved labels see this link
