Hi, I was trying to get intersection between several items by using List.Map, for example: I have 2 horizontal surface and 3 vertical surface, the data structure I’m expecting would be {[(0,0)(0,1)(0,2)][(1,0)(1,1)(1,2)]}. However, if the first surface failed to intersect with other 3 surfaces, I’m only getting {[(1,0)(1,1)(1,2)]}, and if the second one failed to intersect, I’m still getting{[(1,0)(1,1)(1,2)][EmptyList, EmptyList, EmptyList]}, which is correct. For me, it feels like dynamo tends to wipe out the empty list/null value at the beginning until the note can successfully get some results. This can be very tricky and important to keep data structure same for future use. Any thought?
