How do I use curvature analysis in Revit or Dynamo? Is there a way?
Please give advice or example, thank you
you can evaluate surfaces with surface.curvatureAtParameter() node or Derivative at parameter
U and V canβt be greater than 1:
http://dynamoprimer.com/en/05_Geometry-for-Computational-Design/5-5_surfaces.html
Try to insert a PolySurface.Surfaces node after PolySurface.Chamfer and see what you get. Surface.GetIsoline is waiting for surfaces as an input.
Has been successful, thank you for your guidance
