Curly brackets error
I’m trying to follow this:
And when I c+ p I get the error saying >>Error: “{” expected<<
Anyone shed some light on it for me please? :slight_smile:
are you using Dynamo 2.x ? If so,use square brackets instead.
a = [ 1 , 2 , 9]
also regarding the function you are defining, you are missing the “{”
See below for an example
As @salvatoredragotta has pointed out { } was replaced by [ ], however contrary to the documentation while defining functions { } was always required along with a return.
In a current version, it would be something like this
Thanks guys!
I’d already replaced the [ ] on the lists but it was telling me I needed {
So if I understand this; you need curly brackets around the output? Is that right?
Also, why does the } go on a new line and not right after the output?
It lets me put the { on the same line as the output.
