Create SystemTypes, how?
I want to create for each class in the document a SystemType…
i am not sure, wether i handle it well, my code so far
clr.AddReference('RevitAPI')
#from Autodesk.Revit.DB.Structure import *
#from Autodesk.Revit.DB.Mechanical import *
#from Autodesk.Revit.DB.Electrical import *
#from Autodesk.Revit.DB.Plumbing import *
import System
clr.AddReference('System')
tGroup = TransactionGroup(doc, "Create and Set MEP-Systems")
tGroup.Start()
#t1 = Transaction(doc, "UndefinedSystemClassification")
#t1.Start()
#_undefinedSystemClassification = MEPSystemClassification.UndefinedSystemClassification
#_uSC = Mechanical.MechanicalSystemType.Create(doc, _undefinedSystemClassification, "UndefinedSystemClassification")
#t1.Commit()
t2 = Transaction(doc, "ReturnAir")
t2.Start()
_returnAir = MEPSystemClassification.ReturnAir
_rA = Mechanical.MechanicalSystemType.Create(doc, _returnAir, "ReturnAir")
t2.Commit()
t3 = Transaction(doc, "SupplyAir")
t3.Start()
_supplyAir = MEPSystemClassification.SupplyAir
_rA = Mechanical.MechanicalSystemType.Create(doc, _returnAir, "SupplyAir")
t3.Commit()
_exhaustAir = MEPSystemClassification.ExhaustAir
_dataCircuit = MEPSystemClassification.DataCircuit
_powerCircuit = MEPSystemClassification.PowerCircuit
_supplyHydronic = MEPSystemClassification.SupplyHydronic
_returnHydronic = MEPSystemClassification.ReturnHydronic
_telephone = MEPSystemClassification.Telephone
_security = MEPSystemClassification.Security
_fireAlarm = MEPSystemClassification.FireAlarm
_nurseCall = MEPSystemClassification.NurseCall
tGroup.Commit()
OUT = [_undefinedSystemClassification,_returnAir,_supplyAir,_exhaustAir,_dataCircuit,_powerCircuit,_supplyHydronic,_returnHydronic,_telephone,_security,_fireAlarm,_nurseCall]
will there one day a autocomplete ? like in PyCharm f.e.?
with the look up - i was not realy sure to find the correct SystemType…
KR
Andreas
You will have to import the Mechanical namespace to access the classes and methods
add import Autodesk.Revit.DB.Mechanical to your imports and after this you can access the classes via Mechanical.<ClassName>
@Mike.Buttery ,
i tested but it does not work
import System
import sys
tGroup.Start()
#t1.Start()
#t1.Commit()
#t2 = Transaction(doc, "ReturnAir")
#t2.Start()
#_returnAir = MEPSystemClassification.ReturnAir
#_rA = Mechanical.MechanicalSystemType.Create(doc, _returnAir, "ReturnAir")
#t2.Commit()
#t3 = Transaction(doc, "SupplyAir")
#t3.Start()
#_supplyAir = MEPSystemClassification.SupplyAir
#_rA = Mechanical.MechanicalSystemType.Create(doc, _returnAir, "SupplyAir")
#t3.Commit()
#t6 = Transaction(doc, "PowerCircut")
#t6.Start()
#_powerCircuit = MEPSystemClassification.PowerCircuit
#_pC = Electrical.ElectricalSystemType.Create(doc, _powerCircuit, "PowerCircuit")
#t6.Commit()
t7 = Transaction(doc, "PowerCircut")
t7.Start()
_sH = Plumbing.PlumbingSystemType.Create(doc, _supplyHydronic, "SupplyHydronic")
t7.Commit()
tGroup.Commit()
KR
Andreas
Hi @Draxl_Andreas
Here’s some corrected code
see my notes below in this code for explanationsn # NOTE :
import System
import sys
# NOTE : NAMESPACE CONFLICTS
# NOTE : DO NOT IMPORT ALL from Autodesk.Revit.UI NAMESPACE
#clr.AddReference('RevitAPIUI')
#from Autodesk.Revit.UI import *
# NOTE : NOT NECESSARY TO LOAD ASSEMBLY SYSTEM WITH IRONPYTHON OR PYTHONNET IT'S LOADED BY DEFAULT
#clr.AddReference('System')
tGroup.Start()
# NOTE : THIS NOT POSSIBLLE TO CREATE AN UndefinedSystemClassification FOR MechanicalSystemType
# t1 = Transaction(doc, "UndefinedSystemClassification")
# t1.Start()
# _undefinedSystemClassification = MEPSystemClassification.UndefinedSystemClassification
# _uSC = Mechanical.MechanicalSystemType.Create(doc, _undefinedSystemClassification, "UndefinedSystemClassification")
# t1.Commit()
t2.Start()
t2.Commit()
t3.Start()
_rA = Mechanical.MechanicalSystemType.Create(doc, _supplyAir, "SupplyAir")
t3.Commit()
# NOTE : THIS NOT POSSIBLLE TO CREATE AN NEW ELECTRICAL SYSTEM TYPE IN REVIT
#t6.Start()
#t6.Commit()
tGroup.Commit()
OUT = 0
Your code has imported every class from the Plumbing namespace with import * but not the namespace itself
