Create Simple DropDown Node
Update:
I solved the problem by importing the library through a package. I my case it was necessary to create the package as an local one with the Dynamo prompt. As long as i only copied the files in my package folder dynamo installed it but never imported the library properly.
Here is the post: C# Dropdown
grafik
using System.Collections.Generic;
using CoreNodeModels;
using Dynamo.Graph.Nodes;
using Dynamo.Utilities;
using ProtoCore.AST.AssociativeAST;
using System.Windows;
namespace SampleLibraryUI.Examples {
        [NodeName("Drop Down Example")]
        [NodeDescription("An example drop down node.")]
        [IsDesignScriptCompatible]
        public class DropDownExample : DSDropDownBase
            public DropDownExample() : base("item") { }
            protected override SelectionState PopulateItemsCore(string currentSelection)
                // The Items collection contains the elements
                // that appear in the list. For this example, we
                // clear the list before adding new items, but you
                // can also use the PopulateItems method to add items
                // to the list.
                Items.Clear();
                // Create a number of DynamoDropDownItem objects
                // to store the items that we want to appear in our list.
                var newItems = new List<DynamoDropDownItem>()
                new DynamoDropDownItem("Tywin", 0),
                new DynamoDropDownItem("Cersei", 1),
                new DynamoDropDownItem("Hodor",2)
                Items.AddRange(newItems);
            // Set the selected index to something other
            // than -1, the default, so that your list
            // has a pre-selection.
                SelectedIndex = 0;
                return SelectionState.Restore;
            public override IEnumerable<AssociativeNode> BuildOutputAst(List<AssociativeNode> inputAstNodes)
                // Build an AST node for the type of object contained in your Items collection.
                if (Items.Count == 0 ||
                  SelectedIndex == -1) //NB! This line is crucial for some reason
                    MessageBox.Show("Item.Count gleich 0");
                    return new[] { AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), AstFactory.BuildNullNode()) };
                var intNode = AstFactory.BuildIntNode((int)Items[SelectedIndex].Item);
                var assign = AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), intNode);
                return new List<AssociativeNode> { assign };
