Create sections from corridor stations in Dynamo
Hello. I apologize for the translation, I hope you will understand me. I have a question about creating cross-section groups from the corridor pickets. How can I link the width of the left and right cross sections to the offsets of the corridor targets in Dynamo?
Hi and Welcome.
I did some testing and almost passed the finish lines but when you write ”corridor targets” do you mean that you want to collect all targets or targets specific to the Sample line width?
KR
Patrick
What have you tested to far? A picture that show a little bit more than one node is a better way to get help at the forum. I always suggest a new user to read the thread “How to get help…”
Anyway, here is one way to deal with it if you have offset targets to set the width of the sample lines. As you see with my selected polylines I tested with offset polylines to get an offset value on left and right side of the corridor baseline/alignment
Then there is a screenshot and the script. It might be that you need to change the levels to make is work
Home.dyn (42.2 KB)
Best regards,
Patrick
Good morning. This is what I need, thank you very much. It’s even better than my idea. I previously created a corridor to create a cross section on the corridor pickets, but with your script, I no longer need a corridor. thank you.
