Hi all,
I’m trying to make different lists of elements that share the same Y value.
This is what’s I’ve tried but now I’m a little stuck.
Thank you!
@RoelB ,
you can use groupByKey node to sort your points
or do want to set specific points by other points(Y) ?
KR
Andreas
Thanks, but it’s not about the point.
It’s about sorting element by coordinates.
Hola Amigo @RoelB buenas. you can always group items using his index like this, you can also sort by value first if that is you are looking for, i let you the image i hope this works for you! ![]()
Thank you.
Every unique Y value needs to create his own list with elements that contain this Y value.
In the example above, I only collect the location of those elements.
