Create list by adding the element after every loop
Hi All. I am running a loop in dynamo to get individual elements from the list.
the issue is I need to add the individual item each time to a list after each loop and see afterwards if the number of items in the new list is the same as those in the old list. That way I can tell if the run has been completed and delete all the old elements
I don’t use the Loop While very often, because, as I understand it, it requires numerical Functions to allow Dynamo to understand how to control the loop…
Start at 1,
+10
until value is greater than 100
output = 101
I think the problem is that you’d need to find a way of making ‘is the number the same as the previous list’ into a Function. However, as I understand it, a Function cannot have inputs, it is a formula.
In Python, there is the construct:
i = 0
while i < (value) :
   do something
   i += 1
Which gives greater flexibility in determining the ‘value’, so that is the way I would start to investigate.
To give more explicit advice, I think it would help if you could give us a simple graph to look at?
Hope that helps,
Mark
I managed to solve it with the pass through node
