Create hyperlink
Is it possible to create hyperlink (from path) in the Dynamo Player Outputs?
By clicking on this link it goes directly to the right adres in explorer.
Hey,
I wouldn’t have thought so, I expect they are going to be String outputs… but you could probably have the graph create a popup which has a hyperlink?
Hope that helps,
Mark
Ha,
Thanks but this is not what i had in mind, for now i will continue to use CTRL-C en CTRL-V.
You can provide a link in the dyn properties but it has to be a URL. Currently Dynamo does not support local or network paths.
