Create a subList of repeated item, but only one time in a list - PYTHON
Hello DynamoUser,
I’d like some help solving my problem… I am not a Python User but I’m doing my best to learn.
Here is the issue : I would like to obtain a List of lists from a initial list, that contains only the element that are repeated more than once, but only one time.
EXEMPLE IMAGE :
0 appears only one time, so I don’t want it in the final list
1 & 2 appears twice, so I want them in the sublist of the final list
3 appears twice so I want him in the sublist containing 3 and 4
4 appears 3 times
5 same as 3
So as I said, not a Python User
But here is the beginning of my reflexion
(only read the dynamo primer course so…)
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
#List that contain multiple list of the number we want to assemble
IN[0]=List_Of_IndexToAssemble
#List that contain multiple list with the numbers that appears more thant once, but only one time
result=[]
#GOAL : ADD THE NUMBER_a only one time in a list IF IT APPEARS MORE THAN ONCE with the NUMBER_b + AND + Also take count the NUMBER_c in the list with the other number i NUMBER_c is with NUMBER_b
#Check in all list, it the number appears more than ONCE
for counter in List_Of_IndexToAssemble
	if counter.List.Count > 1
	result.append(counter)
	#If it appears more than once, put it in a _sublist_ with the others that appears with it
#Create a List with all _sublist_
OUT = result
Thanks all for your prescious time
Eric
Hello
a solution using set operator
def checkuniq(lstobj):
	#flatten
	flatt = sum(lstobj, [])
	outList = []
	for sublstx in lstobj:
		if not all([flatt.count(item) == 1 for item in sublstx]):
			common = []
			for sublsty in lstobj:
				#search commons sublist
				inters = set(sublstx) & set(sublsty)
				if inters:
					common.extend([sublstx, sublsty])
			#get the largest common sublist
			finalcom = sorted(common, key=len)[-1]
			if finalcom not in outList:
				outList.append(finalcom)
	return [list(x) for x in outList]
varlst = IN[0]
OUT = checkuniq(varlst)
Note
not work if elements of a sublist is communs with others differents sublist
Thanks you !!
amazing you made my day friend.
Eric
