Create a List full of lists that are flattend
@maldemu96 so you got the expected result?
Okay guys, it worked perfectly! So i tried to adress some other issues. Now a got a different problem :joy: do you guys know why my if script doesnt work?
PS: i tried refereing penetrationheight and width with IN[2][0] and so on
PS2: solved
The if penetrationtype... test and following lines are indented and will be causing a syntax error
On to a solution…
The flatten function needs to handle the edge cases - a string, a single value, a list of length 1
def flatten(items):
    def is_iterable(item):
        return hasattr(item, "__iter__") and not isinstance(item, str)
    if is_iterable(items):
        out = []
        for i in items:
            if is_iterable(i):
                out.extend(flatten(i))
                out.append(i)
        if len(out) == 1:
            return out[0]
        return out
    return items
Then map the function across the input
    hvactypecombined,
    penetrationtype,
    penetrationheight,
    penetrationwidth,
    penetrationdiameter,
    wallmaterial,
    walldepth,
    firerating,
    hvactype,
) = map(flatten, IN)
To handle the diameter we don’t need the if... else as it’s already set to 0 or some other value and I’m confused because if it is rectangular we set the diameter to 0, that’s OK - if it’s not rectangular (i.e. circular or oval) we are setting the diameter to half the maximum of width or height, so this will be the radius? Why not just set the diameter?
I set it zero just to create the code and some parameters are not involved yet. It is atm just a placeholder.
Hi @maldemu96,
Please try using this example:
Picture 1: This is a simple example that demonstrates how to flatten multiple lists using nodes.
Picture 2: This will give you an idea of how to set the levels.
