For items that don’t generate a preview image. I put placeholder X_____X.
Edit: please paste entire python script and I can explain which bits do which
# coding: utf-8
clr.AddReference('RevitAPI')
app = uiapp.Application
import System
from System import Environment
from System import Array
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import *
clr.AddReference('System.Windows.Forms')
from System.Windows.Forms import Clipboard
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
class ExcelUtils():
def __init__(self, expSettings, filepath, sizebitmap):
self.expSettings = expSettings
self.filepath = filepath
self.sizebitmap = sizebitmap
print self.filepath
def exportXls(self):
ex = Excel.ApplicationClass()
ex.Visible = True
ex.DisplayAlerts = False
workbook = ex.Workbooks.Add()
workbook.SaveAs(self.filepath)
ws = workbook.Worksheets[1]
nbr_row = len(self.expSettings)
nbr_colum = len(self.expSettings[0])
xlrange = ws.Range[ws.Cells(1, 2), ws.Cells(nbr_row, nbr_colum )]
xlrange.EntireRow.RowHeight = self.sizebitmap.Height
ws.Range("a1").EntireColumn.ColumnWidth = self.sizebitmap.Width / 4
a = Array.CreateInstance(object, nbr_row, nbr_colum - 1)
for indexR, row in enumerate(self.expSettings):
for indexC , value in enumerate(row):
if indexC == 0 and value is not None:
Clipboard.SetDataObject(value)
rng = ws.Range[ws.Cells(indexR + 1, 1), ws.Cells(indexR + 1 , 1)]
ws.Paste(rng, False)
a[indexR, indexC - 1] = value
#copy Array in range
xlrange.Value2 = a
used_range = ws.UsedRange
for column in used_range.Columns:
column.AutoFit()
toList = lambda x : x if hasattr(x, '__iter__') else [x]
listcat = toList(UnwrapElement(IN[0]))
#make filter
lstbipCat = [System.Enum.ToObject(BuiltInCategory, x.Id.IntegerValue) for x in listcat]
filtercat = ElementMulticategoryFilter(List[BuiltInCategory](lstbipCat))
#collector
fecSymb = FilteredElementCollector(doc).OfClass(FamilySymbol).WherePasses(filtercat).ToElements()
fecsNew = []
for fec in fecSymb:
if fec.FamilyName == "Model Text":
pass
fecsNew.append(fec)
catName = []
sortedsymbs = []
for s in fecsNew:
fam = s.Family
cat = fam.FamilyCategory
catName.append(cat.Name)
sortedsymbs = [x for _,x in sorted(zip(catName, fecsNew))]
exceps = []
outdata = []
imgSize = Size( 100, 100 )
for symb in sortedsymbs:
try:
if not symb.GetPreviewImage(imgSize):
bitm = "X---------------------X"
bitm = symb.GetPreviewImage(imgSize)
famName = symb.Family.Name
symbName = Element.Name.GetValue(symb)
fam = symb.Family
catName = cat.Name
try:
famDoc = doc.EditFamily(fam)
if not famDoc.PathName:
path = ("Family location not found")
path = (str(famDoc.PathName))
famDoc.Close(False)
except:
path = ("This is a system family")
except Exception, e:
exceps = str(e)
outdata.append([bitm, famName, symbName ,catName , path])
#define folder to export
directory = System.Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments)
objXls = ExcelUtils(outdata, directory + '\\Family_Container.xls', imgSize)
objXls.exportXls()
OUT = directory
So I know this part determines what the path output is
try:
fam = symb.Family
catName = cat.Name
try:
famDoc.Close(False)
except:
exceps = str(e)
I am still not sure why it’s empty though. And apparently only detail items and generic models all have problem generating a preview image.
https://revitforum.org/showthread.php/37169-Preview-Image-Generator-(P-I-G-)
I can only think this plug-in could help.
It’s interesting that you pointed out this tool. This is actually what I am currently using as an alternative to this library document. Still not exactly what I wanted but this would help if someone was browsing within the family folder. I have updated all my detail families preview images and they are all optimized. I am still getting no preview image through the script. I was thinking about trying @c.poupin original script with just the detail item category feeding the script, but I figured the imgSize part is the exact same so it wouldn’t yield any different result.
Edit: I decided to update the generic models with the P.I.G. tool and now I am actually getting a preview image. So the tool actually helped to an extend. Maybe the tool is generating preview images for detail items in a way that isn’t working with the script.
Ah, so this is why. That sucks. The weird part also is that there is obviously a preview image for detail items (either plan view or whatever active view/sheet was on) and that preview image also shows as a file thumbnail, but it just doesn’t show in the user interface. So for some reason Revit either only recognize something else other than that data, that’s why it’s not showing the actual thumbnail, or Revit just disable thumbnails for all detail items. I wonder if there is a way to communicate to Revit to just use the file thumbnail, instead of asking Revit where they would have usually stored their thumbnails, if that makes sense.
Edit: A dumb way to get around it might be to have a different script, or just edit within the original script, to extract the detail item thumbnails, and do a copy and paste onto the spreadsheet, where the file names matched, maybe this could be achieved within the Microsoft framework and would have nothing to do with Revit, since I have already went through all my detail items and use P.I.G. to update their thumbnails. Updating the thumbnails would probably be part of the workflow for future families anyway.
The Revit API only seems to have their own PreviewImage property but as you say maybe there might be a Python Library that could get an image that way. I think the script could be altered to do that if such a python module could be found.
Right. I am not at all an expert with Python, and I am not too familiar with Revit API. I will ask people who knows Python and see if they can think of any method that can achieve getting preview images from the detail item families (file thumbnails) and paste it in the spreadsheet where names matched. Basically bypassing Revit. Because it seems like it’s not quite possible to get preview images from Revit anymore. Hopefully this will go somewhere. In the meantime, if anyone has any idea or any suggestions please drop a comment below, it’ll be greatly appreciated.
