CopyPasteOption ().SetDuplicateTypeNamesHandler( IDuplicateTypeNamesHandler handler)
Hi All,
Does anyone know how to convert the following code to Python (from the sample SDK)?
CopyPasteOptions options = new CopyPasteOptions();
options.SetDuplicateTypeNamesHandler(new HideAndAcceptDuplicateTypeNamesHandler());
class HideAndAcceptDuplicateTypeNamesHandler : IDuplicateTypeNamesHandler
	public DuplicateTypeAction OnDuplicateTypeNamesFound(DuplicateTypeNamesHandlerArgs args)
          return DuplicateTypeAction.UseDestinationTypes;
clr.AddReference('RevitApi')
from Autodesk.Revit.DB import DuplicateTypeAction
dta = DuplicateTypeAction.UseDestinationTypes
OUT = dta
This should be sufficient though:
Hi, could you please post your result?
I don´t get it to work. I want to replace families if the same name already exists. Currently it copies the object and adds a new family with the same name ending with a consecutive number.
options = CopyPasteOptions()
options.SetDuplicateTypeNamesHandler()
# I struggle with this area
#options.SetDuplicateTypeNamesHandler(new DuplicateTypeAction.UseDestinationTypes)
#DuplicateTypeAction.UseDestinationTypes
#new IDuplicateTypeNamesHandler
copy = ElementTransformUtils.CopyElements(linkDoc, eId, doc, tf1, options)
class CustomCopyHandler(IDuplicateTypeNamesHandler):
def OnDuplicateTypeNamesFound(self, args):
custom_handler = CustomCopyHandler()
copy_options = CopyPasteOptions()
copy_options.SetDuplicateTypeNamesHandler(custom_handler)
Snag_14f4940
I don’t work much with python, but when I see the error is this maybe the solution?
custom_handler = CustomCopyHandler().OnDuplicateTypeNamesFound()
Hi @jw.vanasselt, thanks for your response! I tried your script, it doesn’t work.
I wonder if it is a dynamo issue. I tried my original script in revit python shell, it’s working out fine. Very strange!
The problem relate to Cpython3 inside Dynamo, with RevitPythonShell still runing in Ironpython3, I’m not sure team fixed it in Revit 2024.2 yet.
I see interesting, thank you!
