Hi. I m trying to copy data from one text parameter to family type name. I created a Dynamo script, but I get a warning: “Warning: Element.SetParameterByName operation failed. The parameter’s storage type is not a string.”
What if you try to make it a string with the String from object node? and then pass it into name?
This means that the input has to be something else than a string. Check the Storage Type of your parameter.
I guess that storage type for Type Name is Element Type. But I still dont know how to make my script work and if it is possible to push data to Type Name. Thanx though )
No, I think Type Name is Read Only, you will need to set the Type parameter instead…
Maybe this topic could give you the right direction?
