Concatenate lists by index
Hello, I am a new user of Dynamo and I get stuck with a problem, hope someone can help me
I would like to concatenate 2 lists by using index as reference
The resulting “+” node should be
In the first list:
1(m) CCE cota = 64,926248 (concatenating the “0” indexes)
2(m) CCE cota = 82,519167 (concatenating the “1” indexes)
3(m) CCE cota = 108,90854 (concatenating the “2” indexes)
In the second list:
1(m) CCE cota = 80,830560 (concatenating the “0” indexes)
2(m) CCE cota = 102,821709 (concatenating the “1” indexes)
3(m) CCE cota = 135,808432 (concatenating the “2” indexes)
Instead, the list only concatenate the first two items with the rest of the first list
Is there a way to fix this?
Thanks in advance
Do you want like this
a = IN[0]
b = IN[1]
c = []
for n in IN[0]:
    for i,j in zip(n,b):
        c.append(j + "-"+ str(i))
n = len(IN[1])
OUT = [c[i * n:(i + 1) * n] for i in range((len(c) + n - 1) // n )]
hi
cordially
christian.stan
That’s exactly what I need, thank you a lot!
That’s also a solution for me, thank you for sharing
