Compare two huge lists
I have two lists. List A contains around 2000 rooms with around 10 boundary curves → total 20000 curves. List B contains all walls curves around 9000 curves. I want to compare every curve on list A to all of the wall curves on list B.
This process takes me forever.
My goal is to take the nearest wall, and match it with the closest room boundary curve.
room.boundaries doesnt work, coz all the walls are from linked model, but my rooms are on current model.
Which version are you using? No problem in getting Geometries with my Dynamo 2.6.1.
The only problem is that your model is so big.
You can get the the elements defining the room using a python script node like this;
import sys
clr.AddReference("RevitAPI")
rooms = UnwrapElement(IN[0])
result = []
for room in rooms:
    roomBoundingElements = []
    nestedRoomBoundaries = room.GetBoundarySegments(SpatialElementBoundaryOptions())
    for nestedBoundary in nestedRoomBoundaries:
        for boundarySegment in nestedBoundary:
            roomBoundingElements.append(doc.GetElement(boundarySegment.ElementId))
    result.append(roomBoundingElements)
OUT = result
I don’t know if this is what you need, because I could not understand when you mentioned “the walls are from linked model”. However, I tried this on 4000 rooms and it listed all these in a couple of seconds
yes my project is big
even I do it manually level by level it takes so long time.
I used your python script for matching the closest distance between curves
your script last time:
but still takes long time like 1 hour
import sys
dataEnteringNode = IN
# Place your code below this line
geos1=IN[0]
geos2=IN[1]
min=IN[2]
bools=[]#determin set
dists=[]#distance between set
for geo1 in geos1:
	temp=[]
	dtemp=[]
	for geo2 in geos2:
		bool = False
		dist=geo1.DistanceTo(geo2)
		if dist<min:
			bool=True
		dtemp.append(dist)
		temp.append(bool)
	bools.append(temp)
	dists.append(dtemp)
OUT = bools,dists
Maybe some workaround can be found if the final result you want is known.
