Combining two nested lists
Hi all,
I am looking for a way insert the lists of one nested list into the other in an alternating fashion. Here is an example of what I am trying to accomplish.
Most advice I have found through searching indicated a python script may be necessary to accomplish this. I am unfortunately a beginner in Dynamo and have no coding experience.
Any advice would be much appreciated! Thanks,
-Matt
This should get you there out of the box! :slight_smile:
First, you create a list from both inputs, then you transpose them (Note: This may not work for jagged lists of different lengths), then you flatten the list structure.
So much more simple than I was making it… Thanks!
