Collect / filter elements from a list which contains "IsHIdden" attribute
HI Everyone,
I’m trying to collect elements hidden in views for which I tried
  1. collect elements from prject
  2. Use a python scipt that can find hidden elements in view
It works fine for elements in active view but if I try to collect all the elements from project,
"How do I filter those elements which do not have a specific attribute named “IsHidden” ?
Warning I get when I try run the script:
Script:
clr.AddReference('RevitAPI')
def toList(obj):
    if hasattr(obj, '__iter__'): return obj
    else: return [obj]
elements = toList(UnwrapElement(IN[0]))
views = toList(UnwrapElement(IN[1]))
elementsHidden = []
elementsNotHidden = []
for view in views:
	for element in elements:
		if element.IsHidden(view) is True:
			elementsHidden.append(element.Id)
			elementsNotHidden.append(element)
OUT = elementsHidden
Any leads can be of real help :slight_smile:
Hey,
Have a look in Archi-lab? There is a custom node which unhides elements… you can have a look at the Python in there?
Cheers,
Mark
Hello
a few solutions
for view in views:
		if element is not None:
			if element.IsHidden(view):
## OR ##
for view in views:
		if hasattr(element, 'IsHidden'):
or try to remove nulls from input list (elements) with OOTB node
