Hi all member,
Please help me, How can change the name of the Project location use Dynamo.
Thank you!
Resolved ![]()
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
clr.AddReference(‘RevitNodes’)
from RevitServices.Persistence import DocumentManager as DM # Document manager
from RevitServices.Transactions import TransactionManager as TM # Transaction manager
NewName = IN[0]
doc = DM.Instance.CurrentDBDocument
TM.Instance.EnsureInTransaction(doc)
projloc = doc.ActiveProjectLocation
NEW = projloc.Name = NewName
TM.Instance.TransactionTaskDone()
OUT = NewName
Thank boss!
Hi @chuongmep,
Thanks for sharing this code. I am testing it but I get this error:
I just pasted your code on a Python node. Is it there anything else I have to do?
Thanks in advance!
Try, i thinks that is a problem with dynamo version higher " vs '
clr.AddReference(“RevitAPI”)
clr.AddReference(“RevitAPIUI”)
NewName = IN[0]
OUT = NewName
Hi @chuongmep,
Thanks for coming back. I finally managed to make it work! It is really useful. The issue was the type of token, for some reason Dynamo 2.0.2 does not recognise ´, ’, “ or ”, but yes " or '. Maybe it is a matter of keyobard language or symbols.
By the way, now that the rename current Project Location works, I am wondering if there is a way to rename multiple Project Locations of current document. Or even better from linked documents. Sorry, I am pretty new with Python…
Thanks!
Hi @chuongmep,
I managed to change name to multiple locations. Please see below. Last step that I would like to achive is to do it from a Host model to several linked instances. If you have any idea it would be appreciated. Thanks for the support!
# Import RevitAPI
clr.AddReference('RevitAPI')
app = uiapp.Application
# Do some actions in a Transaction
ProjectLocations = UnwrapElement(IN[0])
NewCurrentLocationName = IN[1]
NewLocationNames = IN[2]
CurrentLocationElement = list()
NamedElementsList = list()
ExceptList = list()
CurrentLocationID = doc.ActiveProjectLocation.Id
for ProjectLocation, NewName in zip(ProjectLocations, NewLocationNames):
try:
if ProjectLocation.Id == CurrentLocationID:
ProjectLocation.Name = NewCurrentLocationName
CurrentLocationElement.append(ProjectLocation)
ProjectLocation.Name = NewName
NamedElementsList.append(ProjectLocation)
except:
ExceptList.append("Error"+ProjectLocation.Id)
# Finish Transaction
# Final Output
OUT = [CurrentLocationElement, NamedElementsList, ExceptList]
what are the package of location.byname
