Change null property to zero
Hey, i tried to create this code to change the null number of two properties to zero but im getting error saying that the parameter type is not a sequence of characters, text
Try using the number 0 instead.
The value provided has to align to the storage type for the parameter, so if it expects a number (double) or a count (integer) you need to provide a numeric value which converts accordingly.
Now it works but the list is changing only one parameter
Lacing and list levels for both nodes need to be adjusted. Longest and you can just provide a single 0 as the value.
