Is it possible to change the model space World UCS with Dynamo? I want to create keynotes that are relative to a rotated coordinate system. I can’t seem to make Dynamo understand that the UCS needs to change.
Can you show an example?
Can you show this part?
You can create and set UCS definitions with the Arkance Systems Node Library. Maybe that will help?
You could also try using the Object.Transform node to rotate the MLeaders after you’ve created them.
Sounds good! I’ll give those ideas a try.
Does this (or perhaps I should say could this) allow transforming the “origin” point to something closer to the object origin prior to bringing things into the Dynamo environment, and then transition back once elements are created?
crosses his fingers
Smart thinking, but unfortunately no. Only the Editor functions like Select respect the UCS, all other (like an Alignment’s startpoint or endpoint) look at the WCS.
