Learn
Explore
Blog
Forum
Roadmap
Resources
Primer
Dictionary
Developer
Builds
DesignScript Guide
Help Center
Get Dynamo
Privacy
Dynamo
Change material cut pattern with dynamo
Revit
dynamo
1bitBoolean
May 20, 2024, 12:28pm
1
574×846 16.5 KB
I want to change these 2 with dynamo but can’t find the node for it. My current node tree has seperated out all the materials I wanna change but closest thing to changing pattern is material.color, which changes color of surface which I don’t want.
haganjake2
May 20, 2024, 12:53pm
2
441×556 37.3 KB
Use Genius Loci
enslin
March 23, 2026, 12:07pm
3
Hi there, seems like node does not work with Revit 2026, not sure if you noticed the same
material Colours
2740×902 141 KB
Related topics
Topic
Replies
Views
Activity
Create Material
Revit
19
10142
July 19, 2019
Material surface patterns in Dynamo? Revit/Lumion/Dynamo workflow
Revit
archi-lab
dynamo
10
2218
March 27, 2025
Material render appearance
Revit
2
258
January 11, 2023
Override Material colour in 3D Active View
Revit
revit
python
dynamo
13
1996
May 6, 2022
(wall material change node) Is is possible to make it more simply using python script?
FAQ
revit
python
dynamo
0
415
June 11, 2020
