Cant import random module to Python
I’m trying to import the random module into python and the node throws and exception. Any ideas?
I’ve tried
import random
and
    import sys
    pyt_path = r'C:\Program Files (x86)\\IronPython 2.7\Lib'
    sys.path.append(pyt_path)
to no avail. The IronPython console has no issue with import random and works as expected
You would first have to define a path to IronPython’s librar, append it to the system path and then finally import the module.
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
import random
dataEnteringNode = IN
OUT = random.random()
Works as expected:
This works for me: (Edit: to late)
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import random
OUT = random.randint(0,9)
Thanks guys. Thought it was going to be something simple I was overlooking!
This works for me too:
