Calculation of steel desing in RSA2025 with Dynamo
Hello!
I am trying to write a code to calculate steel. I found examples on the forums that worked, but after using them in my file, I get an error:
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReference(user + r"\Dynamo\Dynamo Revit\3.2\packages\Structural Analysis for Dynamo\bin\interop.RobotOM.dll")
from RobotOM import RobotApplicationClass, IRDimCalcParamVerifType, IRDimCalcParamLimitStateType
clr.AddReference("System.Reflection")
from System.Reflection import BindingFlags
from RobotOM import *
from System import Object
class ComObj:
    def __init__(self, obj):
        self.obj = obj
        self.typ = obj.GetType()
    def __getattr__(self, name):
        def newm(*args):
            args = args or (None,)
            return self.typ.InvokeMember(
                name,
                BindingFlags.InvokeMethod | BindingFlags.GetProperty,
                None,
                self.obj,
                *args,
        return newm
objects = IN[0]
app = RobotApplicationClass()
project = app.Project
project.ViewMngr.Refresh()
rdm_server = IRDimServer(app.Kernel.GetExtension("RDimServer"))
rdm_server.Mode = 1
rdm_calc_engine = IRDimCalcEngine(rdm_server.CalculEngine)
calc_param = IRDimCalcParam(rdm_calc_engine.GetCalcParam())
calc_conf = rdm_calc_engine.GetCalcConf()
stream = IRDimStream(rdm_server.Connection.GetStream())
stream.Clear()
stream.WriteText("all")
calc_param.SetObjsList(IRDimCalcParamVerifType.I_DCPVT_GROUPS_VERIF,stream)
calc_param.SetLimitState(IRDimCalcParamLimitStateType.I_DCPLST_SERVICEABILITY,1)
stream.Clear()
calc_param.SetLoadsList(stream)
rdm_calc_engine.Solve(stream)
all_results = IRDimAllRes(rdm_calc_engine.Results())
detailed_results = IRDimDetailedRes(all_results.Get("1"))
case = detailed_results.GovernCaseName
ratio = detailed_resuls.Ratio
OUT = case, ratio
I don’t know what this error is caused by, and I’m not quite sure what I should plug into this script under “objects = IN[0]” I created the membertype and group necessary for calculations and they are working well.
import sys
clr.AddReference(user + r"\Dynamo\Dynamo Revit\3.3\packages\Structural Analysis for Dynamo\bin\interop.RobotOM.dll")
dataEnteringNode = IN
Rygiel = IN[0]
# Place your code below this line
bars = app.Project.Structure.Bars
select = app.Project.Structure.Selections.Create(1)
select.FromText(IN[0])
labeltype = bars.SetLabel(select,16,"Rygiel")
OUT = Rygiel
import sys
Rygiel = IN[0]
structure = project.Structure
labels = structure.Labels
bars = structure.Bars
objects = structure.Objects
#Obliczenia
app.Preferences.multiprocessing = True
dim = project.DimServer
connect = dim.Connection
groups = dim.GroupsService
#grupy
g1 = groups.New(0,1)
g1.Name = "Luk"
g1.Material = "S 235"
strm = connect.GetStream()
strm.Clear()
strm.WriteText(str(Rygiel))
g1.SetMembList(strm)
grpprof = connect.GetGrpProfs()
grpprof.Clear()
strm.WriteText("IPE")
grpprof.SetFamilies("RPLN7",strm)
g1.SetProfs(grpprof)
groups.Save(g1)
OUT = Rygiel
Most, as not all, of the interface classes used here are not available in the API documentation, because when looking for particular functions, they simply weren’t there, but in the above code found on the forum, you can see working classes, not described in the API. I looked for additions to the API, but did not find them. Is there any additional documentation to fill in these API gaps? I’m also not entirely convinced, through lack of access to documentation, exactly what each function does.
as explained here : Calculation of steel desing in RSA2025 with API - Autodesk Community
you need to define the group number as an integer value
detailed_results = IRDimDetailedRes(all_results.Get(1))
note also that solve does not take parameters
rdm_calc_engine.Solve(None)
if you only have one group (number 1) to calculate, you can define it as follows
stream.WriteLong(1)
class ComObject:
        self.obj = obj
    def __getattribute__(self, name):
        def newm(*args):
                name,
                None,
                self.obj,
                *args,
        return newm
objects = IN[0]
rdm_server.Mode = 1
stream.Clear()
stream.WriteLong(1)
stream.Clear()
OUT = case, ratio
After making the changes, now this is what my script looks like, but it continues to get the same error I wrote about above:
You must set calc_param to rdm_calc_engine
rdm_calc_engine.SetCalcParam(calc_param)
Hi @230826
in addition to @Stephane.Kapetanovic’s answers
try to replace
by
sys.path.append(r"C:\Program Files\Autodesk\Robot Structural Analysis Professional 2025\Exe")
clr.AddReference("interop.RobotOM")
save and restart DynamoSandbox or/and Revit
Thank you very much, now it works!
Hello!
I’m trying to set instead of I_DCPVT_GROUPS_VERIF to I_DCPVT_GROUPS_DESIGN, but I’m not quite sure what I’m doing wrong and how I should proceed further to get results with I_DCPVT_GROUPS_DESIGN.
There is my script:
class ComObject:
        self.obj = obj
        def newm(*args):
                name,
                None,
                self.obj,
                *args,
        return newm
objects = IN[0]
rdm_server.Mode = 1
stream.Clear()
stream.WriteLong(1)
calc_param.SetObjsList(IRDimCalcParamVerifType.I_DCPVT_GROUPS_DESIGN,stream)
calc_param.SetLimitState(IRDimCalcParamLimitStateType.I_DCPLST_ULTIMATE,1)
stream.Clear()
grp_results = IRDimGrpResCurrProf(all_results.Get(1, I_DGRCP_GOVERNING))
detailed_results = IRDimDetailedRes(grp_results.Get(1))
ratio = detailed_results.Ratio
print(ratio)
print(case)
OUT = case, ratio
@c.poupin
