Suppose I am creating a ZTList Zero Touch library, and it has the following classes:
- ZTElement: stores an integer property
- ZTList: keeps a list of ZTElements
These classes are implemented as follows.
ZTElement.cs:
namespace ZTList
{public class ZTElement { protected int _i = 0; public int I { get { return _i; } } protected ZTElement(int i) { _i = i; } static public ZTElement Create(int i) { ZTElement ztElement = new ZTElement(i); return ztElement; } }}
ZTList.cs:
namespace ZTList
{public class ZTList { List<ZTElement> ztElementList = new List<ZTElement>(); public List<ZTElement> GetList() { return ztElementList; } protected ZTList() { } static public ZTList Create() { return new ZTList(); } public ZTList Add(ZTElement ztElement) { ztElementList.Add(ztElement); return this; } }}
So the ZTList.Add() method modifies the ZTList instance by adding a ztElement to the intrinsic list.
Then I make the following graph.
This is supposed to add one ztElement to the ztList. Now the problem is, if I disconnect any input to the ZTList.Add() node and reconnect it again, I am adding the same ztElement to the ztList. The screenshot below shows the state of the graph after a few re-connections.
I believe I am not using the correct philosophy here. This may be more sensible in an ordinary Object-Oriented Programming environment, but perhaps this is not recommended in Dynamo. So I am just wondering what the best practice is.
- Should I deep copy the input ztList, thus making copies of the existing ztElements in the list?
- Or is this a bad node design altogether, and such modification should not be allowed?
Many thanks,
John
