Hi all,
I’m having some issues with Batch Save Utility and a script I’ve made.
I’ve tested the script on it’s own and it works just fine, but when I use it with the utility I get a Failed to save error.
I’ve added the script links to both Trusted Locations and Support File Search Path, in both Civil 3D and Autocad, all version that I have installed, still no go.
This is the script:
ATTSYNC
N
BUR-A0-Landscape
ATTSYNC
N
BUR-A1-Landscape
ATTSYNC
N
Z-Zz_10_70-R1_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R2_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R3_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R4_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R5_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R6_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R7_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R8_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R9_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R10_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R11_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R12_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R13_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R14_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R15_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R16_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R17_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R18_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R19_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R20_A0-Rev
ATTSYNC
N
Z-Zz_10_70-R1_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R2_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R3_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R4_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R5_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R6_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R7_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R8_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R9_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R10_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R11_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R12_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R13_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R14_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R15_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R16_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R17_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R18_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R19_A1-Rev
ATTSYNC
N
Z-Zz_10_70-R20_A1-Rev
qsave
close
Y
quit
Anyone got any idea what I’m doing wrong?
Thank you.
Edit, This is what I can see in the log:
**** System Variable Changed ****
1 of the monitored system variables has changed from the preferred value. Use SYSVARMONITOR command to view changes.AutoCAD menu utilities loaded.
Command:
Command:Command:
Command: ATTSYNC
Unknown command “ATTSYNC”. Press F1 for help.
