Hello ,
I’ve seen some examples of building a parametric construction, but my question is:
Is there a way to place (in Advance Steel) the beams, columns, plates, etc according to the list described in external data file? If yes - which way would you suggest. - Dynamo/Python script?
I have already wrote a modeller for 3D designs that suits the company I work in, but I also like the way Advance Steel is building production drawings. I can export a file that will contain all the geometry data and I was thinking about a script that will build the variable constructions according to the imported geometry in AS.
I was not using Dynamo yet, but I just wander if the idea is not too complicated and worth of learning it.
