Hi i am new with ironpython, and i am having problems with converting some python libraries into ironpython while coding in dynamo in revit.
Someone please tell me the basics of converting a python script to ironpython?!
could you help me with this script as an example?
from selenium import webdriver
from selenium.webdriver.chrome.service import Service
from selenium.webdriver.common.by import By
import time
service = Service(r’C:\\Users\\shanm\\chromedriver.exe’) # Using raw string for Windows path
driver = webdriver.Chrome(service=service)
url = “https://www.environdec.com/library/epd8104”
driver.get(url)
time.sleep(3)
try:
pdf_element = driver.find_element(By.LINK_TEXT, “EPD document S-P-08104 en.pdf”)
pdf_url = pdf_element.get_attribute(“href”)
print(“Extracted PDF URL:”, pdf_url)
import requests
pdf_response = requests.get(pdf_url)
if pdf_response.status_code == 200:
with open(“EPD_document.pdf”, “wb”) as f:
f.write(pdf_response.content)
print(“PDF downloaded successfully!”)
print(“Failed to download PDF. Status code:”, pdf_response.status_code)
except Exception as e:
print(“Error occurred:”, e)
finally:
driver.quit()
Hello @uaftab.cem19 - Curious if you need to use IronPython? It’s a language we’ve not supported now for numerous years and will stop working at some point in the not-to-distant future.
Depending on what version of Revit you are in, we would suggest switching to CPython
If you are in Revit 2025+, then you can use the “PythonNET3” engine which is on the package manager now, but will be the out of the box version soon.
There seems to be a well-structured public API at https://www.environdec.com/.
For example, if you look at this public link, you will find all the data, including the PDF ID.
https://api.environdec.com/api/v1/EPDLibrary/EPD/epd8104
So you don’t need Selenium, just requests.
import sys
import System
import json
import urllib.request
import urllib.error
from urllib.request import Request, urlopen
from urllib.error import URLError, HTTPError
my_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments)
def data_request(url):
try:
req = Request(url, headers={"User-Agent": "python-urllib/3"})
with urlopen(req, timeout=30) as resp:
content_type = resp.headers.get("Content-Type", "")
raw = resp.read()
# if JSON, decode and load; else return raw bytes
if "application/json" in content_type or "text/json" in content_type:
# pick charset if provided, default to utf-8
encoding = resp.headers.get_content_charset() or "utf-8"
text = raw.decode(encoding, errors="replace")
return json.loads(text)
return raw
except HTTPError as e:
print("HTTP error:", e.code, e.reason)
except URLError as e:
print("Connection error:", e.reason)
return None
OUT = []
url = "https://www.environdec.com/library/epd8104"
ref_product = url.split("/")[-1]
url_api = f"https://api.environdec.com/api/v1/EPDLibrary/EPD/{ref_product}"
response_data = data_request(url_api)
if response_data is not None:
for data_doc in response_data["documents"]:
if data_doc["name"].endswith("pdf"):
id_pdf = data_doc["id"]
name_pdf = data_doc["name"]
url_pdf = f"https://api.environdec.com/api/v1/EPDLibrary/Files/{id_pdf}/Data"
pdf_byte = data_request(url_pdf)
print(type(pdf_byte))
with open(f"{my_path}\\{name_pdf}", "wb") as f:
f.write(pdf_byte)
OUT.append(f"{my_path}\\{name_pdf}")
Notes
- I have only tested 2-3 technical data sheets.
- Check the site’s terms and conditions to see if downloading is permitted in this way (if not, you will need to use their REST API).
