AttributeError: 'Document' object has no attribute 'NewDuct'
I am just starting to try Dynamo and Python, and this is probably a very basic question.
My problem appears when I create a new Revit project, open Dynamo 1.3.3, and create a basic python script to create a duct form (0,0,0) and (5,5,5). Then I get the error
AtributeError: ‘Document’ object has no attribute 'NewDuct’
Code is as follows:
# Import RevitNodes
#import Revit DB
clr.AddReference('RevitAPI')
#import Revit Creation where Create.Duct is
from Autodesk.Revit.Creation import *
# Import Revit elements
from Revit.Elements import *
# Import DocumentManager
import System
x = IN[0].ToXyz()
y = IN[0].ToXyz()
#ductType = IN[3]
#ductTypeUnwrapped = UnwrapElement(ductType) #not working
# Start Transaction
doc.Create.NewDuct(x, y, ductType); #if DuctType is null then Revit picks first type.
# Stop Transaction
OUT = doc
Inputs to the Python block are just two points defined by coordinates.
Thanks in advance
Hi @xberzal
There are couple of items missing in your code. But first which Revit version are you using?
Hi kulkul.
it’s Revit 2019.
Hi @xberzal,
I think where @Kulkul was getting to is that the NewDuct() method was deprecated in Revit 2017. You’ll need to use Duct.Create() method. See Revit API documentation in link below…
http://www.revitapidocs.com/2017.1/6f8b1fa9-5e94-2a31-c921-ec1db957b31b.htm
Also, you are assigning X = IN[0] and Y = IN[0]. This is the same point and will fail as a line based family cannot have coincidental endpoints.
Also, what error are you getting from the UnwrapElement as you say it is failing?
Cheers,
Dan
Thnaks, @Kulkul and @Daniel_Woodcock1, I got rid of the error by using Duct.Create, now I need to define the 5 inputs that are required for this function. I will try to include the full example when it’s working for future reference
I came across this post as I was getting the same error message. I updated the depreciated method as pointed out and ended up with this as a solution.
# Import RevitNodes
#import Revit DB
from Autodesk.Revit.DB.Mechanical import *
import System
doc = IN[0]
x = IN[1].ToXyz()
y = IN[2].ToXyz()
systemType = IN[3]
ductType = IN[4]
level = IN[5]
systemTypeID = ElementId(systemType)
ductTypeID = ElementId(ductType)
levelID = ElementId(level)
# Start Transaction
#Revit 17.1 NewDuct() depreciated
#doc.Create.NewDuct(x, y, ductType); #if DuctType is null then Revit picks first type.
Duct.Create(doc, systemTypeID, ductTypeID, levelID, x, y);
# Stop Transaction
OUT = doc
Here is an Image of the Dynamo Nodes for Reference:
Hi kphillips,
Could you upload an image of the dynamo nodes to accompany this script please.
Thanks in advance
The Image of the Dynamo nodes were uploaded on the previous post. Can you see that?
