Assign a slope to a floor in Revit using dynamo
hi everyone, i would like to know how can i draft slope with floor in dynamo without using modify sub elements!
Yes, you can.
Hi @m.rashadRDLAZ yes can be done, but please show us what you have tried so far, and if you go stuck, then just show us where and we will be happy to help, if we can ;))
Revit_FbNuQ3Da4i
any hints here?:sweat_smile:
sure,
i have tried many ways but finally i started to use a python script from another topic but still have a problem
Python script
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import \*
from Autodesk.Revit.DB.Structure import \*
from Autodesk.Revit.UI import \*
clr.AddReference('System')
profile = IN\[0\]
level = UnwrapElement(IN\[1\])
slope = IN\[2\]
ca = CurveArray()
for c in profile:
    ca.Append(c.ToRevitType())
line = ca\[1\]
floor = doc.Create.NewSlab(ca, level, line, slope, True)
OUT = floor
Hi @m.rashadRDLAZ yeah always best show what you try…but try something here and could maybe work for you :wink:
slope floor.dyn (13.2 KB)
thanks bro but unfortunately when i tried to use my own workflow and define the slope as a percentage like 2% it didn’t work
testooooooooo.dyn (48.1 KB)
try as here, have only test on a single floor
i am trying to solve it but kindly can u tell me what is input 3 & 4 refer to? in python script
and sorry for interruption
no worries :wink:
yeah 3 define the perimeter curve index for slope direction, 4 define the slope
ok just bear with me i took ur original script and modified it to meet my project requirement note that my floor is irregular shape and has a slope with 2.5% but believe me i will destroy my machine if u will not rescue it :sweat_smile:
slope floor updated.dyn (24.7 KB)
allright not at dyn now, but ry take a look on this post specielly @jacob.small post here…How to assign slope to created floor - #18 by jacob.small
ypo are welcome to share the rvt with the cad for take a deeper look :wink:
sure, this is the last updated graph and rh cad file for the floor all i need is to assign a slope maybe 2.5% to the floor
test apron by dynamo.dwg (38.4 KB)
i have only tried on your shared file, and something seems works fine from my side
Revit_VzeLCrOaVA
same script?
same script ??? does it work or not ?
yes, it works but still have 2 issues
1- i need to assign the slope in this direction
2- in script i am putting the slope in angles 2.5 rad but i need to put it as a percentage 2.5%
allright then try take a deep look at Jacobs shared post where he do it with a vector, i havent tried..for rad vs degree maybe its your project unit, guess the python do it in degree, or you could just do some math for convert…
ok bro appreciate your efforts :grinning_face:
allright try as here with option for rotate the direction
11Home.dyn (17.8 KB)
