Hello. I am having some issue with this python script I am making, which uses RevitAPI to duplicate views and change the name. I can duplicate the views just fine but when I want to access the name parameter, it is telling me that I am trying to access an ElementId which has no get_Parameter attribute.
If I understand my code correctly, the duplicate command returns the newly created view’s Id and not the view itself, which is why I have the error.
How would I go about getting the newly created view from duplicate instead of using the Id that it gives me?
clr.AddReference('RevitAPI')
views = []
dupview = []
c = 1
for i in IN[1]:
newView = UnwrapElement(i).Duplicate(ViewDuplicateOption.Duplicate)
newView.get_Parameter(BuiltInParameter.VIEW_NAME).Set("Revision Cloud View " + c)
dupview.append(newView)
c += 1
Thank you.
