Any chance to use European profiles within Dynmao
I tried a lot and also used the reference videos, but didn’t find a way to use European profiles within Dynamo for Advance steel. Is there anyone who did this.
Regards
André
Any thoughts here @okapawal?
Hi @andre.ihde
When creating Advance Steel beams through Dynamo, you can control the section type and section size of the profile created, so you can set any section you want - including the European profiles that are part of the Advance Steel content or, created on your side.
You can check this help page for more information : Assign a Beam Section | Advance Steel 2022 | Autodesk Knowledge Network
