Good morning!
I have a little problem… I can’t understand why the node (angle between two vectors) declare lecture from 0 to 360 degree but it give back data of angles only interior or “more near”… why? any idea?
I would like to have increasing angles… if I use the on right angle rotating it will be always on the right… and not one time on the right one time on the left…
is there a command for to set the correct direction, for example interior angle o external angle?
I hope that this images help you to understand my problem…
thanks for your attention!
Yoseph
